Discuss Underfloor heating?????? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
What is the pipe stat for and where is it located?
Is it to ensure the flow doesn't get too hot (IIRC 65 degree's or hotter)
If the pipe stat is to stop the flow getting too hot and you have to turn it up to get the UFH to work could the pipe stat be wired incorrectly? is this a new or old installation ?.
Reply to Underfloor heating?????? in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
What’s the best setup for a system that has a heating system with existing radiators but a wet underfloor heating system is being added to a new...
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
