Discuss Vertical tv brackets in the UK Electrical Forum area at ElectriciansForums.net
Hi Lads , got asked to hang a tv for a friend of mine but they want it vertical/landscape. do yas know if if i need a special bracket. i cant seem t find one. its a 55 inch but i need it to have an arm to come about 400mm of the wall. Any ideas would be greatly appreciated
How about this!
There are others, but availability seems a bit of a problem!
The four threaded mounting holes built into the back of the TV are in a square, so can be attached in portrait or landscape
Oh, I thought the idea was to 'swivel' the TV between landscape and portrait - like the Samsung 'Sero'. Seems to be a thing to either watch telly (landscape) or play your phone screen through the TV (portrait). But if it's not that, forget the rotating bracket ☹️!
Reply to Vertical tv brackets in the UK Electrical Forum area at ElectriciansForums.net
Hi all, adult learner retraining and sorry if this is in the wrong place but I need help. my provider are being very cards against their chest...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi all, it seems that each time i buy a plasterboard wall plugs to screw into plasterboard either it wont hold the weight of the TV bracket or...
5K
Hi all, I'm an fully qualified electrician based in Dundee, Scotland. I have just completed my BS 7671 Amendment 2 course and my 2391-52...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
