OP
pcasey
So to re-cap…it’s impossible for the volt dropto cause the fuse to burn out as higher resistance or lower voltage at the loadleads to lower current passing through the circuit. Therefore it must be that aloose connection on the fuse terminal that caused the problem, which makessense as 50A left running all night would not do it any good. I might suggest alarger transformer with a thermal cut out and a timer on the primary that cutsout after 5 hours although 5OA left on for 5 hrs is not great either but a600VA transformer should handle it? I could always fit LED lamps but I’m notsure whether they need a specific type of transformer which will be a costly solution….any ideas? Cheers, Phil.
