Discuss wago terminals and wiska 2 part gel in the UK Electrical Forum area at ElectriciansForums.net
J
Jigglybuf
Anyone had much experience using wiska boxes with wago lever terminals
And using the wiska 2 part gel to fill boxes?
After testing continuity after filling the box, am getting continuity between live and neutral showing
a dead short between conductors! Is this just occurring during the curing process? Or are these products just not compatible?
I'm more of a domestic indoor kind of guy, so don't encounter underground joints too often as I struggle to trust them!! which is why I'm asking.
Ther should be no problem with the gel, or the Wagos. The gel has no continuity even when curing. Sounds like a wiring fault.
Did you test continuity and operation before you gelled it?
Hi, as far as I know WAGO does not do 4pole lever connector. Theres 2 pole, 3 pole or 5 pole.
You sure you used 3 connectors to make that joint? One for live, one for neutral, one for earth? Sticking them all in one will result in dead short.
Plug in a continuity tester at the beginning of circuit, let it beep or make some other noise for that dead short, start disconnecting the circuit bit by bit and see where is messed up.
Im thinking the same , the gel type underground joints I have used have been O/K , the other thing I can think of is that with all the rain maybe he hasn't fully closed the joint or it came apart when laying it sand its got water in it ...
Never had continuity when making joints with wiska gel and wago lever connectors - one job had 50 burided JBs all wago lever connectors and all filled with gel and not had a fault in over 3 years!
But a joint affected by water. etc will not show a dead short. You have another problem to resolve!
I will ask again,
Reply to wago terminals and wiska 2 part gel in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi all, I've been having some issues trying to fix a fluorescent light in the bathroom. Here's the steps I've taken so far after it suddenly...
Hi everyone We have a little problem with a heating system on one of the projects (quite big house in south Kensington) and we are looking for...
Hi there. After a bit of advice please. Only reason I am not getting an electrician in is because my son is struggling with Asperger's at the...
10K
Hi All, I am currently in the process of enrolling in a part time evening course to complete level 2 over the course of a year and just have...
