Discuss wanted ip rated low bay light fittings in the For Sale and Wanted Forum area at ElectriciansForums.net
Reply to wanted ip rated low bay light fittings in the For Sale and Wanted Forum area at ElectriciansForums.net
With next week forecast for rain, we thought we’d take a moment to explore what IP ratings are and why it is important to know their meaning. In...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hi all, how easy is it to be able to shorten the drop tube of a semi flush light fitting ? Essentially what tools would I need for cutting the...
