Discuss what cert is required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
not a cu change, old cu rewirable has no means of isolating (cu change would be the right thing) but a lad has just asked me about this
im thinking meiwc
or a eic with just the relevant bits
Reply to what cert is required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Still having a discussion @ work about this…TNCS system DB/CU is a split 30ma RCD configuration,5/5 MCB’S are 60898 what Max Zs would you put in...
Hi Folks Long time no see! I'm retired. I have files of test certs from 2004 to 2018. Moving house. Can I dump them? Cheers! Pete
Hi , Could someone answer the following for me? i don't have reg book handy and when i google i'm getting mixed answers. 1. maximum...
OLDBOY
O
Hello Got a customer who needs certification for a monthly emergency lighting test. What would be the best cert to provide them with? The NICEIC...
Surely if you fit an RCBO on each circuit, an RCD is not required? Of course, a DP Main switch would be to cut all power, but like I ask, is the...
