Discuss What is this? in the UK Electrical Forum area at ElectriciansForums.net
Ruzzell
Does anyone know what these things are? We keep digging these old things up in our yard. They appear to be a hard plastic with some kind of electronics inside them. Thanks.
What’s on the other end of the flex?
Is there any writing on it, or a sticker?
I’m thinking float switch??
How many have you uncovered?
I would be surprised if it was a detonator of any sort.
@Ruzzell I don’t have a clue as to what that is but call City hall and have someone to come out and check it. The electronics inside is what I would worry about
I wonder if they are the transducers for a mole repeller buried underground in a garden. Each one generates a high pitched (modulated?) sound which moles hear as indicative of a potential predator - so they scarper from the area insonified by the transducer stopping a garden from being wrecked by mole hills and tunnelling. The wire goes to a power supply or amplifier.
View: https://www.amazon.co.uk/Battery-Operated-Ultrasonic-Repeller-Deterrent/dp/B00GLT4REO
They look a bit too well sealed to be emitting anything.
They certainly look a bit rough and ready in their manufacture. Just clear tube chopped squashed and sealed. Certainly not made for appearances so perhaps made to be buried. Chopped off and left in the ground after their use was over instead of digging them up.
Some good theories so far, I'm pretty intrigued to be honest. We may never find out though if they are some homemade project.
A good way to figure out their use would be to hand them to someone good with electronics and get them to analyse the contents. BigClivedotcom on youtube springs to mind.
Reply to What is this? in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know what this is found when removing old mirrored wardbrobes
I was looking for the likes of the SQB1603K and see it is out of stock at CEF and no delivery option available. Odd. Then I search for the part on...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
I was working with some odd singles today from Batt Cables, they seemed to have a plastic like braid between the insulation and the copper, almost...
