Discuss What is "unwanted tripping"? in the UK Electrical Forum area at ElectriciansForums.net
Are you aware that Dr. J. Duncan Glover the American electrical expert who diagnosed the cause of the Grenfell Tower fire, doesn't know that there is a fuse in a 13amp plug?
Are you aware that in between the time that the Grenfell Tower fire occurred and the time that the Grenfell Tower fire Inquiry began, the words "temperature rise" were removed from Chapter 41?
The terminology is a carry over from when fuses were the main method of providing overload protection and things like circuit breakers hadn’t been invented or even imagined yet. It has always been known as the “fusing factor”, so it probably always will be.So please explain in simple terms why you would think of using a 'fusing' factor when calculating the size of a 'circuit breaker'?
The clue being the use of the word "fusing" and the use of the words "circuit & breaker".
So why didn't the fuse isolate the fridge freezer?I wasn't aware of either, no. But then I haven't really delved into it.
I dare say hundreds of changes and amendments were made before the final release of the report.
A fusing factor allows you to increase the size of a fuse in order to absorb starting currents.The terminology is a carry over from when fuses were the main method of providing overload protection and things like circuit breakers hadn’t been invented or even imagined yet. It has always been known as the “fusing factor”, so it probably always will be.
What point are you trying to make?
Would it have stopped the fire? Other than the cable the are plenty of things that can catch fire on excess current well below the fuse rating.So why didn't the fuse isolate the fridge freezer?
As above, and that the appliance might well have had 1mm cable (or less).If the fuse was wrapped (as it must have been) in silver paper, why did the cabling catch fire before the 32amp MCB tripped (at a value in excess of 47amps)?
Some link to the report (and section of it you are referring to) would help, otherwise this sound a bit like a YouTube conspiracy rant.Current carrying capacity of 4.0mm T&E 36amps
Current carrying capacity of 2.5mm T&E ring main 45amps (est. max.)
Current carrying capacity of 1.5mm T&E spur 19.5amps
Whilst I'm on:
Why did Colin Todd, the designer in essence of every fire alarm system in the Country, forget to mention in his (and the only) report into the fire that the fire alarm system failed?
See section 433.1Therefore you don't need to use a fusing factor when calculating the size of a circuit breaker!
I think you might be getting confused by the factor for rewirable fuses.Therefore you don't need to use a fusing factor when calculating the size of a circuit breaker!
The 1.45 fusing factor is already included in both BS88 fuse & MCB ratings and is also factored in to cable ratings.
A cable rated to carry 32A does not explode in to flames at 33A, in fact it will carry a lot more before obvious thermal stress occurs, but in the region in between the lifetime of the cable will drop dramatically.
Similarly a fuse or breaker rated at 32A does not trip at 33A, generally they trip in an hour or so at 45% more to provide some margin between the design rating, manufacturing tolerance, and variations in environment (as a fuse is a thermal device, as is a MCB below the magnetic trip point) that have a significant impact on trip times for light overload cases.
There are times and places when you might want faster and tighter protection that is also simple, but so far that is not common outside of laboratory power supplies. But if anyone is interested, so is ESA for something better for spacecraft use and are willing to pay more than half a million Euros for a study project (reissued, replies by 28 Jan 2021 please):
Title ELECTRONIC CIRCUIT BREAKER FOR TELECOM PLATFORMS (ARTES AT 4F.138) (RE-ISSUED)
The objective of the activity is to design, manufacture and test an electronic
circuit breaker suitable for all electronic units in a telecom platform.
Targeted Improvements: Improving the response time by two orders of magnitude
and voltage control by an order of magnitude; Enable simplified power
management on the unit side; Enable reset of the power protection.
Description: Telecom platforms supply power to all their units via fuses.
Because of the physical process of melting a material to open the electrical
line, the time needed to actually open the circuit can vary significantly.
Moreover, a very high current is needed. Therefore,the whole platform has to
be designed to cope with very large current transients. Since every unit is
supplied through a fuse, the number of them needed in every platform is quite
high. An electronic circuit breaker is an attractive alternative to a fuse for
the telecom market. Its performance would be more predictable and it would
operate much faster and with lower current. The current can be sensed in an
accurate way and the time needed to open the line can be finely controlled by
an electronic circuit. Moreover, this circuit can also cope with the overload
case where the consumption of a given unit has gone out of its nominal range
but still has not produced a short circuit. Finally, the circuit can be reset
by command, which gives a significant increase in flexibility during the
integration phase of the satellite. In this activity, an electronic circuit
breaker shall be developed, manufactured and tested to verify its capability to
replace fuses. Since this electronic circuit should be able to power any unit
in a telecom platform, the voltage capability should be above 120V and the
current capability should be above 2A. Procurement Policy C1: Activities in
open competition limited to non-Large-System Integrators (LSIs)) as prime.
LSIs are allowed to participate as sub-contractors. For additional information
please go to EMITS news "Industrial Policy measures for non-primes, SMEs and
RD entities in ESA prog
No idea what that has to do with your questions, but it clearly suggests you have an agenda or point, so feel free to share it with the group.Are you aware that Dr. J. Duncan Glover the American electrical expert who diagnosed the cause of the Grenfell Tower fire, doesn't know that there is a fuse in a 13amp plug?
Carry on with insults to established, knowledgeable members and this thread will be gone.Have you never heard the expression "empty vessels make the most noise"?
We are discussing the deaths of 18 children here, that is more than Ian Brady, Myra Hindley, Fred West and Rose West combined, managed to kill!
Therefore just this once:
Of course an operable fuse or the correct size of circuit breaker would have prevented the cabling catching fire at Grenfell Tower, that is what over-current protection does.
If a fusing factor is already built into circuit breakers, as you say, why would you then use a fusing factor for a second time in your calculations.
And if you understood your principles you would realize that a small overload of a long duration will cause temperature rise and eventually fire.
I'm not getting anything confused young man because I understand my principles; over-current protection, safety earthing and fire alarm systems. Everything a 'time served man' should know.
Now please stop trying to confuse the readers with irrelevant facts and misleading guesswork and learn your trade!
Reply to What is "unwanted tripping"? in the UK Electrical Forum area at ElectriciansForums.net
