C
ChuckTH
Okay, this seems to be happening on two separate circuits at my house. 1950s house - newer 200A service in basement and a sub-panel upstairs. The lighting circuits up are essentially ungrounded. (older, silver cloth covered, romex looking stuff. So - I'll explain one of the examples. I have a 20A circuit in basement main panel serves microwave and a light fixture in the pantry. I've followed all the wires in that circuit and opened all the junctions/boxes/outlets etc. It's all newer romex - no "mixing" with older wiring or sharing of neutrals etc. Then I have a 20A lighting circuit coming off my sub-panel that also powers a few bedroom outlets. When I turn off that sub-panel circuit. It all becomes unusable BUT, at one 3-way switch on the hall light and at a light fixture in the linen closet, my "volt sensor" still senses current. (It doesn't seem to be enough to power anything or hurt anyone) but anyway, when I flip the breaker downstairs on that microwave circuit then that "phantom current" in the lighting circuit goes away. I thought maybe I was sharing a neutral or something but like I said, I checked that whole circuit. Is this probably something feeding back through a ground? Like I said, I've got another 2 circuits doing essentially the same thing. What's happening here? How much of a concern is it? and what's the best procedure for running it down? - Thanks!!
Hi - the cheap non contact voltage sensors are reliably unreliable, in my humble opinion. The cable might be live (hot) or it might have a floating (ghost) voltage induced on it from other nearby cabling that is genuinely still live.
- nothing else near these wires though.
Just to add.... In the case of the "ghost current" in the example I gave, I've been able to determine that if I unplug the microwave, it goes away. What might that mean? I've read a bit about "induction" and phantom load draws from appliances etc. - but I'm still confused. Anyone?... Thanks
It’s hard to say what’s going on but you the microwave needs to be on its own circuit
Who can help me understand this...?
ChuckTH,
Megawatt,
