Discuss Wiring light switch in the Lighting Forum area at ElectriciansForums.net
Aimeee
Hi, I've moved in to a property that has 2 cellar lights, one at the top of the stairs and one at the bottom. The one at the top of the stairs works, I switched the bulb at the bottom of the stairs and it still doesn't work. When I've taken the switch off the wall there are a couple of wires that aren't connected to the switch, can anyone advise what is going on? Pictures attached
The fact there is wires disconnected may mean there was a fault and by doing this they have made it safe, but removed the two way functioning of the two switches.
You should get an electrician to check the wiring with proper test equipment and have it repaired.
Don’t just connect them back up where they should be.
I can't see any disconnected wires in the pics. What I do see is a 2G1W switch with a 3&E using the blue as a neutral feed to the switch box, connected to the outgoing black to the light controlled by the half of the switch connected to the T&E, the red of the 3&E is the permanent live feed to both half of the switch, and the yellow being used as a switch return to another light.
Reply to Wiring light switch in the Lighting Forum area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
