Discuss Would you advise getting all the GN publications or is OSG + 7671 + GN3 enough?? in the UK Electrical Forum area at ElectriciansForums.net
You always need BS7671
AFIK for the accreditation schemes you also need the OSG as it has a few guidance aspects not in the formal regs (like distances for fixing cables) as well as the "standard circuits" and minimum CPC sizes for common MCB which take a lot of uncertainty and mistakes out of 90+% of domestic work.
The GN are useful and having GN3 and GN8 is a very good starting point to cover most odd questions you encounter. if you can afford it then getting the whole set is a good idea, but it is not cheap.
I bought the complete set for 18th edition, but only updated GN3 & GN8 when amendment 2 came out. However, I am not in the normal sparky business.
Reply to Would you advise getting all the GN publications or is OSG + 7671 + GN3 enough?? in the UK Electrical Forum area at ElectriciansForums.net
I recently sold my Renault Trafic as it had done 214,000 miles and I also wanted something more economical. I bought the Citroen Berlingo LWB. A...
I wanted to thank you all who have subscribed to the forum. Really really helping right now as Google has dropped off a cliff. So you're literally...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
