Discuss wylex mcb online supplier in the Electrical Tools and Products area at ElectriciansForums.net
C
coticsam
Hoping some one could help me out, im trying to source wylex 20a mcb, a type c and d. I am not an electrician so did not kniw about differant types etc, I googled what I wanted and brought some, turns out I ordered a psb type, these do not fit my bus bar, psb has a hole type fixing were as all my others have a slot, afer research it turns out I need a nsb type, I spoke to eleconline which is were I got thenew ones from and they said I need the older type which they can order from wylex at £20 each, new ones were £5 each,new google search but cant find anything
generally find that obsolete breakers are at a premium price. try online for "the old fuse co". or ebay.
Reply to wylex mcb online supplier in the Electrical Tools and Products area at ElectriciansForums.net
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
