Discuss display lights in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Hi all this is not my usual thing but, I had a look at a a jewelery display for a shop it has three 12V bulbs and a 230V rotary motor for the display, it is now on its 3rd lighting transformer and now it will only light 2 bulbs if three are fitted they go on and off about every 10 seconds, the transformer has three outputs, also there is a capacitor coupling the motor and tranny circuits is it possible this is at fault, what are the specs I should look for (output etc) when ordering a new transformer as I just copied what was fitted, I have a feeling that the bulbs fitted are of the wrong wattage as they have been replaced by the shop owner
P
has he fitted halogens in place of LEDs?
P
I'd be definitely binning the transformer and re-wiring the lights with GU10 holders and using 230V LED lamps.
Reply to display lights in the UK Electrical Forum area at ElectriciansForums.net
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
