Discuss Plastic versas Metal CU's - your chance to vote in the UK Electrical Forum area at ElectriciansForums.net
This 2 screw terminal business....agree. Problems occurred because of change over to mcb's, which only have the one terminal screw, a different type altogether.
'Oh, well we might as well make N and E a row of single screw terms on a sliver of brass ' save a chunk on production cost.....and who even mentioned it at the time?
Yep. Double terminal screws and fixed busbars would sort the issue much better than metal CUs IMO.
Have you seen these in city's? I know it's only the main switch with twin screws but it's a start in the correct direction. Also the circular terminal is better IMO.
I'm still awaiting a response from Keith Smith at BEAMA to the following email I sent him:
"Keith
I appreciate your candid response and openness.
The quality of fuseboards has progressively dropped over the last 20 years and now they are so flimsy, and I'm not just referring to the, completely flimsy cases, it's the quality of the main switches, the mounting bars, the MCB's the RCBO's - this is what needs fixing.
Introduce a requirement for main switches to have 2 screws per terminal would be a step in the right direction and that coupled with improving the "strength" of the busbar for the MCB's and RCBO's would be good too.
My point remains that you can improve the case BUT ignoring the internal components and in some cases dangerous workmanship is not dealing with the problem."
I still believe the main problem is sparks in a rush getting the busbar in behind the screw, rather than it not being tightened properly, hence fixed busbars being better.
Not the point I'm making.....it's all in the 'industry' of making money. Who the hell worth his salt needs to apply torque settings to correctly connect a terminal. One thing leads to another and it's not 'the blind leading the blind'....it's those with their eyes wide open.
the main problem, IMO, is the fact that main switches and RCDs will only accomodate a very short length od conductor in the terminal. anything over 1/4" leaves copper showing. having 2 screws and at least 1/2" of copper in the terminal will cure 75% of the problem.
And that's scientifically proven :) (in 73.67% of cases )
I think main switches should have two screws per terminal like in meters. Loose connections are how most fires start so why not think about how to stop a fire starting rather than how to stop it spreading?
far too simple a solution for IET. why use common sense when a load of ambiguous waffle generates income?
Why is it the electrical industry seems to be more prone to knee jerk reaction changes from the powers that be without any analysis of the information presented to them, LFB has spoken and the IET has jumped in feet first
At the stroke of an amendment are all those CU's that have been installed on the back of the 17th edition now non compliant and will they have to be replaced:biggrin::biggrin:. I sense another load of customers getting stung again
You’ve only got to read some of the threads on here to see that some of the unscrupulous so called “electricians” will be using this as an opportunity to fleece customers.
What many don't realise with these type of modular connections,is that you need to flatten out the conductors, if left uniform it will not bite down on the whole conductor, and just fall out with not too much force.
If the installation is otherwise sound, particularly on the basis of all in-CU connections, then the non-retrospective nature of BS 7671 should not make this necessary. That said ... all customers should be presented with an unbiased summary of the risks that their electrical installation presents. I agree with your point, we have all seen the way that the unscrupulous present the 'evidence' and press customers to take action that is in the dealers' and not necessarily the customers best interest! I am, like others, also concerned of the potential impact of a fault that I have missed becoming an incident that injures or maims. If it could be argued that a metal CU may have reduced the severity of the incident or eliminated the incident altogether, how do I demonstrate in court that I have discharged my duties as a professional?
The annoying thing is that I felt the need to make a comment like that. Unfortunately we all know it is a true statement of fact.
Funny how things turn full circle given time.
That Wylex CU in all it's different configurations was revolutionary when they first hit the market in the early 50's!!
I'd like to see what happens to the frame when tested with this 960'C test wire, because i've tried to burn this treated and matured hardwood frame in the past.... Unless this wood was in constant contact with the red hot burning embers on the fire, there was no chance, and even then was reluctant to continue burning, preferring to glow and carbonise than to burst into flames!!!
I do not know the test setup for the glow wire test ... but if the wire were only held at one end I expect it might bend. Testing modern plastic enclosures @ 960°C must be like putting a hot knife through butter!
So Maybe those old wood frame Wylex boards could still pass the Amd 3 tests then... lol!! The internals and the original covers were made of a bakelite material, so they would definitely stand up to the 960'C Glow Wire test....
Ha. Wouldn't that be ironic if it did pass.
I'm thinking the only place where it would fail (relating to the Amd -3 enclosure requirements) is it being an open back design, ...but then if the material it was mounted to was also proven to be non combustible, ...then maybe!! lol!!
It would not surprise me if they did via the non-combustible route according to the test criteria that Damien published. Therefore another example of 'non-combustible' according to the relevant standard. I find it hard to believe that a 'glowing wire' can concentrate sufficient energy at its tip or even along its length to ignite solid timber.
The 960°C test is three turns of nichrome wire wrapped around the test piece. The rest I’d have to look up regarding time, wire spacing and test piece size.
Excellent.
yes I am not sure about Bakelite and when you can safely assume it will ignite or is damaged by heat. It being a thermoset and all.
It would,
I’ve been doing some digging around about phenolic plastics and the 960°C hot wire tests.
Like E54 I’ve tried to burn the Wylex wooden frame. Plain and simply it just doesn’t burn.
I had a coal fire when I replaced my wylex (made aprox 1970 and cream in colour) and the wooden frame got thrown on my fire. It did burn eventually lasted a couple of hours, but a modern consumer unit would have gone in minutes.
"Keith
and THIS is his response:
"HI xxxxx,
Picking up on your point - the drafting committee is made up of a wide range of 'interested parties' and 'industry experts'. The outcome is the consensus of their deliberations PLUS the public consultation (they call this stage a DPC = Draft for Public Comment) that was put out in December 2013 and closed in March 2014.
I can also confirm that the primary 'root cause' that was the catalyst for this particular regulation was agreed by all parties to be loose connections.
We will (as manufacturers) continue to consider any improvements that further enhance fire safety in addressing the root cause.
You make a reference to 'muppits' and in this respect we also find ourselves as Piggy (Miss) in the middle.
Best regards
Keith"
All I can add is Rxllxcks.
Loose connections - yup BUT the quality of the crxp materials doesn't help!
All im going to say on the matter is if i have a bucket with a hole in i will fix the hole ,its ----- footing round a problem of why consumer units are catching on fire that should be looked at , poor quality screws poor workmanship etc etc etc
"HI xxxxx,
Best regards
Keith"
You can't get much clearer than that reply as to who BEMA is looking after and it's certainly not the general public or the artisans that install there members products... The public consultation results were in all probability ----ed in to ''File 13'' ...eg the bin!!
One has to now ask the now very prudent question of, are the DNO's going to be made to use Metalclad Service Heads on all it's new installations?? Or doesn't all the plastic Service Heads count in this shambolic new regulation regarding fire-proof electrical enclosures?? General use service heads haven't been made of any form of metal since the second world war, and are currently actually deemed as dangerous in many cases...
You couldn't make this stuff up if you tried!!
The DNOs fall outside the scope of BS7671 so the answer would be no.
What the F**k has that got to do with anything?? Exactly the same situation exists (according to BEAMA/IET) no matter who's scope it falls under!! Service heads are all fundamentally plastic, so are subject to the same risk of fire is it not??
That's what happens, when knee jerk solutions are applied to situations, instead of addressing the actual problem. It always invokes other/further problems to be addressed, and will continue to do so until the underlying problem is sorted...
It has everything to do with it. They do not follow cable CSA when wiring house supplies nor volt drop on street lighting so why would they start here.
Don't be bloody daft, if the plastic is deemed to be a fire risk in CU/DB's then it applies to any electrical protective device enclosure, it doesn't suddenly change it's properties according to whose scope it falls under... It just goes to show how shambolic this knee jerk solution actually is!!
So your issue is wider then. None of the regs apply to the DNOs so you are saying that needs addressing. I wouldn't disagree with you on that. That is a different argument. But right now it doesn't, so I am not going to waste my time worrying about service heads that have nothing to do with me or BS7671.
I'm just bumping some of the older threads in the general electrical forum that had a lot of replies. They might not be current topics, if they're not, just ignore them and they'll soon drop off the list. If you DO wish to add a reply and get the conversation going again, feel free to do so. Your input might help somebody else in the future.
I'm just bumping some threads in the Electrical Forum, don't mind me while I do this, you don't have to respond to them. Although if they are still current topics, and you do wish to reply, you're welcome to. Keep the thread on-topic and make sure you stick to the forum rules though.
Reply to Plastic versas Metal CU's - your chance to vote in the UK Electrical Forum area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
  • Poll
I did a poll last year on exactly this. Below I have pasted what I wrote in thread last time so there is a degree of similarity. We can then see...
7K
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
4K
This was prompted by me seeing a couple of videos of cone/step drill being used to make holes in a CU. I use a step bit quite often, especially in...
5K
