Discuss 3 core feeding 2 lighting circuits sharing a neutral in the UK Electrical Forum area at ElectriciansForums.net
L
Lukerthomas
Hi can any one help please doin some work on a house and one of the problems on the test report is there's a 3 core feeding 2 breakers ( red feeding downstairs lights and yellow feeding upstairs lights) and only the one nuetral. Now if I could rewire it I would cables concreted into the floor and can't find the other end to sort it (old house probably plastered behind a wall) now can I put both lives into one breaker feeding both circuits with one neutral solving the problem as it's now one circuit ( 2 feeds lol) I no probably not but any help would be appreciated
Are they the only two circuits in the place? Is the load on each circuit low enough for this to work?
Hi there's a couple other breakers on the board all lighting old rewirable board , is that what you ment? The load should be ok but I haven't measured yet it's on a 5 amp at the mo I think. could I put a 10 amp in on a 1.5 can't remember what max current is for 1.5 will check THANKS FOR REPLY
'Should be ok' ?????
Thanks only thing is I'm not the tester and if he pulls me or the client up on it (tester probably won't know) be nice to know if the general Senecas is its ok lol I'll screen shot it so if there's any other opions would be good thanks again
You will be testing it and signing your name to it after you have completed the remedials though so it is up to you to make sure it is safe and compliant.
I would imagine the three core would go to a junction box under the boards somewhere then two T&Es will be connected to that for the two respective lighting circuits with the common neutral.
So although it's not right I don't think this would give rise to danger due to an 'open neutral' on either circuit- however the best compromise is to put the yellow and red in the same OCPD, how many lights are there in total on the existing set up and are there any multi lamp GU10 spots or anything like that ?
That goes without saying Dave.
Don't forget to use the maximum wattage possible for every lighting point, and derate to known installation methods including Cf if connecting to a BS3036.
You don't think this is dangerous!
What planet are you on?
That's the thing I don't no if it's compliant? Also I won't be testing or signing the tester will be coming back to check the work is done then he will be retesting and issuing cert
It's not many it's the rear lights of downstairs and 1st floor no gu10s or nothing ye tried finding where it joined off to can't find it anywhere so this is pretty much the option I'm left with! The tester has condemned the way it is in 2 breakers sharing neutral but if I put into one breaker current promitting will it count as one circuit and get away with it?
Maybe you need to check in the regs to see whether it will be compliant or not then ? I would start with the area of the regs that deals with the size of neutral conductors.
Unless the client is prepared to pay for rewiring I'm afraid that's the best you can do. Use a 6 amp B type MCB though,nothing bigger, that will be fine as the lights will never all be on together for any significant time and even if they were you'd be under 6 amps.
Ok you tell me how you'd get an open neutral at any fitting on either circuit with the appropriate fuse out, if it's wired as I suggest ?
You're moving the goal posts, you never specified at a fitting.
It would be easy enough for someone to pull one fuse at the fuseboard and disconnect the neutral without realising the dangerous situation.
Your post implied that it is not dangerous as it is at the moment and that the only possible danger is that of the borrowed neutral.
No mention of the fact that the neutral conductor will be carrying twice the current it was designed to, possibly carry twice the short term overloads.
Your post implied there was no danger in a potentially very dangerous situation!
If you don't know the regulations on something as basic as this are you sure you are competant to be doing the work?
What a idiot how is it basic how often do u come across that? There's been bout 10 ppl comment on here no one has given me a definate yes or no! Now why comment if your not going to help there ppl like you in every forum! Bet I'm more competent and qualified than u!
It's basic because it's been in the regulations for many many years. You are dealing with the basic rule that you cannot share a neutral between two circuits and the basic definition of a circuit.
Nobody will give you a definate yes or no because they don't want to be liable from handing out advice to someone who appears to not even know the basics of the job.
I don't bet, and I'm not sure how to compare competence but if you seriously wish to compare qualifications then go for it.
So why did u ask me all the questions about it if it was a simple no? And you said "should be ok" so why say that if it's a no? No one is going to be liable for trying to help on a forum where are you from? Just wanted to no as it's not simple it starts as 1 circuit a 3 core and I would obviously change it if I could, so you've offered me no help so why get involved?
Just read about the last 20 of your threads have you got nothing good to say to no one please don't reply anymore to my threads I'm fed up with trolling and keyboard warriors!
I was quoting your comment of 'should be ok' and mocking it.
Who said its a simple no?
Jesus wept, a circuit is defined by being connected to a common OCPD. What more do you need?
It is simple 1 OCPD = 1 circuit
Boys ... stop this bickering now!
Davesparks - Go a little easier on him he's a new member, I take it he's got little experience and questioning what he's learnt and what he has dropped on his lap ... its like shouting at a learner driver , we were all there once.
Lukerthomas - Please don't call members idiots regardless of what they say it only can lead one way once the verbal slating is added, we have a report option at the bottom left of the post if you feel you need to complain then use it and we will decide what actions if any to take.
Carry on but without the bickering please or the thread is closed.
No I'm not Dave, I clearly said that IF the neutral splits to the two areas of lighting before any connected fittings then it wouldn't be possible to get an open neutral situation at any light ,and furthermore I then recommended that both live conductors be connected to one 6 amp MCB, there's no way that the neutral could be subjected to any damaging overcurrent then unless the MCB was faulty,anyway I have no desire to argue with anyone but in the relatively short time I've been a forum member you do come across as rather negative, eager to criticise and even unpleasant at times. However I also realise that it's very easy to get the wrong impression on forums and if I'm wrong I apologise.
Reply to 3 core feeding 2 lighting circuits sharing a neutral in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
