dave19
Morning guys,
I have my first practical exam tomorrow for 2394 Initial verification. I believe one of the 3 short tests is to identify visual faults on a distribution board. What are the other two tests ?
Help would be much appreciated.
Thanks.
One of the others is full initial verification on the board and the other is to sit and go through a load of things and identify faults, this is something other than the board, or was that the 2395 maybe?
Upvote 0
The first of the three small tests is to identify 12 faults or so on a board. I think the other two are insulation resistance test and earth fault loop impede nice but I am not sure.
The other practical which is next week is the full test of a board.
Can someone clarify the first part though ?
Upvote 0
I recall a visual faults test. You have something like a dozen faults and you have to get them all, no more and no less. It's a sod when you are stuck with 11 or 13 :)
I also remember an IR board where you have to test simulated circuits, calculate the fault current, state what kind of fault if any, and state compliant or not.
I honestly can't recall the third one. It may have been EFLI but I don't remember that one at all.
Upvote 0
Hi Andy,
Thanks for that. I think I heard something about EFLI but not entirely sure. Bit nervous as haven't done any testing before.
Reactions: juanmanners
Upvote 0
i did 94 95 same time. 1st was to find 12 faults on the board last, struggled with last 2 especially with the pendant light, i know lol. Then was those photos to code them, then was that global ir test. Then the 3 phase board.
@ op dont panic and think about what you are actually testing.
Good luck
Upvote 0
Good luck
Cheers mate
Upvote 0
I did basic testing as part of 2330 qualification back in 2009. Nothing since. As a Sub-contractor working through agencies on commercial jobs you don't ever get to do any. Never had the opportunity either through the company I was an adult trainee with either.
Upvote 0
You should be fine then. As long as you have covered the basic theory and practical of testing then it will click into place quite easily. I can understand nerves about being out of practice, but just revise test methods and safe isolation until you have it stuck back in there and that should calm you down a bit.
As has been said earlier in this thread, get your copy of GN3 out and read it back to front a few times, going back over the bits that you are unsure about.
Upvote 0
Cheers Andy
Upvote 0
i have the habbit of talking when doing a test like that
because i find people think you didnt noticed some thing just becasue you didnt say it
Did that for my driving, FLT and my 2394/5 tests
but the 2394 is just LOOKING around for faults really
Upvote 0
Morning guys,
Thanks.
----------- website gives amazing info on the practical exam. Definitely worth a look. Good luck
Upvote 0
2394 practical exam
dave19,
Sonia Norman,
Electrical Courses
