Discuss PV+ - anybody heard of this? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi,
I am being touted by my local installer to add a module called PV+ to my residential solar array. This module is claimed to effectively improve efficiency of my installation by 20% (thereby increasing my FiT earnings) by balancing out and reducing overvolting, which they tell me cuts out generation for every period of overvolting. Forgive my brief description but that is as I understand what it is supposed to do!
The module costs GBP859.00 (fully installed) so is something worth finding out about before going for it.
Is there anybody who knows this equipment and can comment on the efficacy of the claims. Many thanks.
Is your inverter regularly tripping out due to over voltage?
Hi Andy,
Not to my knowledge - my Elios4U (and my SolarEdge) don't show any 'gaps' in generation though there are many peaks and troughs.
His ploy is mainly that these overvoltages ARE going to happen and therefore the PV+ module will be working and generating 20% more registered generation, therefore 20% increase in tax free FiT payments. Not, however, prepared to guarantee 20% overall increase so that immediately made me dubious about the whole system.
It is very big in Germany, apparently!
Thanks for your interest.
It's a Matt:e product and I'm sure it has its place, but if you're not suffering from regular over voltage trips then I fail to grasp the point....seems like a solution to a problem that shouldn't exist...I've questioned the ER grid-connection compliance/impact of this technology before, but as yet have not been made to understand the nitty gritty of it tbh
I've not heard of this before. What is it?
And are we talking about overvoltage on the DC or AC side?
If it's the DC side then the system hasn't been designed correctly. If it's the AC side then you should look at getting the DNO to reduce the voltage.
"generating 20% more registered generation, therefore 20% increase in tax free FiT payments. Not, however, prepared to guarantee 20% overall increase"
I don't even know what that's supposed to mean.
Snake oil by the look of it. I would be happy to be shown some evidence to the contrary, but my feeling is that in domestic circumstances, voltage optimisation is unlikely to produce significant savings given the design of modern appliances and lighting. Even the example they quote of the kettle is wrong:
Voltage Optimisation and Solar PV ? matt:e
A kettle is one example of where being over voltage, boiling more quickly will lose you less heat/energy!
Laws of physics start ringing in my head when claims of an additional 20% of energy are made!
if they're talking about using the VO unit between the inverter and the grid so the inverter sees the lower voltage, then this is completely against the regs, and would give the DNO the right to disconnect you. IT's bypassing the G83/2 protection settings that are designed to protect the local grid network from over voltage.
I asked ENA about this last year for a different product and they responded by instructing them to change their instructions and write to anyone they'd sold it to to ensure they weren't doing this (not sure the latter bit actually happened).
I'm not clear that this is what this unit does though, in which case it really is just a snake oil salesman who's talked to the OP.
tbf with the kettle example what they mean is that if it's being boiled when solar is generating then a longer boil time and lower consumption levels will result in the solar providing a higher fraction of the total energy used.
Alternatively just buy a lower rated kettle.
We've got a VO unit in at home as a trial, and basically all it seems to do is to make the kettle and toasters take longer which is pretty annoying for someone as impatient as me. It also always seems to be pretty warm, so I have serious doubts that any minor efficiency gains in any pumps etc are enough to offset the losses in the VO unit.
I did one for a customer in an oldish house, and they then had a central heating pump and valve go within a month, which I put down to the reduced voltage not giving the pump enough ooomph to overcome the start up inertia.
I am still not convinced Gavin, because although I take your point that certain combinations of generated power, kettle power and voltage could work as you describe, most times when voltage is high will be bright sunshine with good output from the panels that has a good chance of covering the kettle.
Guys, don't get sidetracked into the same old VO conversations - I think we all know our opinions on those (at least in a domestic environment anyway), this PV+ unit is pitched as something different....I for one would like to know exactly how this is supposed to differ from VO and how it's compliant to be installed between the SSEG and the grid....I've already decided on its actual value
VMT for all your input guys. Guess I will be leaving my GBP895 in the bank then?
I'm not arguing it's a major impact, just that there is some truth to it.
Ok, thanks, and is the unit manipulating the voltage/supply that the inverter senses and synchronises with? Also, how is the PV+ unit different from a VO unit?
Sent from my iPhone using Tapatalk
Yes the PV + is connected between the grid and the inverter, but not between the meter and the inverter
to be clear, is the inverter backfeeding through the VO transformer?
IT looks like it may not be, and is simply taking the place of a henley block / distro board to make for a neater installation, with the VO unit only operating on the supply (from combined solar and grid) to the house consumer unit rather than the actual PV circuit itself.
Hopefully that's the case otherwise it would invalidate the G83 or G59 protection settings on the inverter which are designed to protect the local grid from over voltage caused (at least in part) by the PV generation.
Gentlemen, the best way to look at the product is like a G59 relay, if the grid reaches statutory limits then the device will switch the inverter out of circuit but on the grid side and not the inverter side.
have you got G83 type test approval for that? There's no mention of it on your website.
Also can you explain what the point is in doing that rather than simply feeding the inverter in on the grid side of the VO unit? I suppose you save the transformer losses for self consumption, but then the voltage at the house side will be higher than if the PV was connected to the other side due to the resistance in the transformer (when the house is exporting).
The manual and wiring diagram don't really make it look like it works in that way.
To satisfy my curiosity would you mind just confirming directly that the PV is backfeeding through the VO unit to export to the grid?
If you actually have managed to produce a decent unit that serves a proper purpose and integrates well with PV without invalidating the G83 type test approvals, then it could be worth us having a look at. I gave up on Vo a few years ago due to the level of unsupported rubbish being spouted about it, and rubbish build quality and support from the units we tried.
Hello Gentlemen, This is my first time on this forum so apologies if I over step the mark. As Matthunt pointed out " look at the product is like a G59 relay, if the grid reaches statutory limits then the device will switch the inverter out of circuit" The important words are "if the grid reaches statutory limits."
Given that the Solar panel system has to comply with the strict requirements of the grid, how can such a relay improve the performance of the solar panel system? Where does the 25% increase in performance all these companies selling the device come from? Is there any hard facts?
Having had a 4kW system in operation for 7yrs and taken readings of the performance of the panels and system over the period, I fail to see the benefits of adding such a device. As such I think it is a waist of money.
I have heard of this (unfortunately).
I discovered some unscrupulous salesman had sold one of these DC PV+ units to my elderly mother, ripping her off to the tune of £2,500. After 6 months her FiT readings were slightly lower than the same period the previous year. I simply put this down to the panels maybe needing a clean. Before installation she was told by the salesman her FiT readings would double!
I'm personally seeing that the firm involved is reported to Trading Standards for this disgusting example of gross miss-selling.
My advice would be avoid at all cost in a domestic situation.
I saw one of these last week from a family member. £3000 if the offer was taken up now, because they were in the area doing other installs and VAT is currently cheaper. £4000 if taken up later because VAT will go up after April to 20% on solar things
This was their sales pitch
  • Our inverter is close to end of warranty (5 years). All the time it's being subjected to spikes in voltage which cause stress and it has to give off those spikes as wasted heat.
  • They will install a "power saver" which will reduce or eliminate the spikes, thus protecting the inverter from all that stress that's lowering it's life expectancy
  • Something about our voltage being over 250V but the power saver will also cause our voltage to drop to 220V which will save money on appliances
  • They will provide a 10 year guarantee for it and for our existing inverter. Replacement would be with a high quality inverter. I asked what the current cost of such an inverter would be today and they said £2500
  • The power saver will make more electricity go back into the grid and increase the revenue from the feed in tarriff by 40% (£300 per year)
  • It will make more electricity available for our appliances and decrease our electricity use by 30% (£200 per year)
After listening to the pitch my family member tried to buy it. If I hadn't suggested we get the advice of a relative in the energy business they would have bought it.
Some web research leads me to conclude they were selling what's known as PV+ which is approximately £700-£1000 fully installed (although that would be without the inverter warranty extension mentioned above) according to random websites I see selling it and a posting on the Money Saving experts forums (I tried to link them but it wouldn't allow me to)
Rob Latta,
I had a very similar sales pitch yesterday and, blow me down, I could get a discount as they had installers in the area.
I listened to the salesman who tells me that all panel arrays have a protection so if one panel goes over the rating for that panel (in my case 240w) then the inverter shuts down THE WHOLE array for 15 minutes so I lose all generation for that period. This may happen 4 - 5 times per day. This “PV Plus” irons these spikes out preventing the inverter shutting down so you record greater generation. He said between a minimum of 25% to a possible 40% depending on season etc.
Cost is £4000, at my current generation and return about 7.5 years to recoup.
Anyone able to corroborate that the panels are shut down so frequently?
Sounds like snake oil to me.
Never seen mine shut down, you can see the generation on a graph online.
Hi,
Hi, ask him to show you his calculations to back up his 20% claim, if your unit is not suffering from over voltage, where is the 20% savings coming from?
Rob Latta,
please report them to trading standards & RECC if they are members, this is a scam based on complete lies, and by reporting the company you may save many others from being ripped off. Thanks.
sue them as well please. Small claims court should be an open and shut case.
I had a reply from the manufacturer of my inverter and I copy their reply in.
“Thank you for contacting us, Inverters are designed to only convert the maximum DC input that the inverter is capable of, it does not read the generation of individual panels. The over voltage issue the PV Plus refers to only occurs in a very small number of systems usually farms and areas that are remote where the supply voltages can be less stable.
The voltage of the PV panels which is DC does not increase with the exposure to more sun, with a small amount of daylight the DC voltage of a PV module is almost at maximum so stays stable throughout the day, it’s the current which is directly affected by irradiance levels, so overvoltage of the PV system is not possible if the system is designed correctly and inverter will not turn off.”
So that solves the question.
Whilst looking into this I did see an in-situ 1 year long experiment with two systems side by side on an industrial estate (one side of a roof with a PV+ system and the other side without). It shows a graph for 1 day with lots of up/down curves for the non PV+ system as it shut down when voltage was too high (compliance with regulations I think?) whereas the PV+ system shows a constant horizontal line because it didn't have to shut down, due to the PV+. The report is in PDF format and is at the light blue link that says "pv-final-data" at this page PV+ Grid Voltage Monitor Unit - http://matt-e.co.uk/are-you-getting-the-most-out-of-your-pv-system/ and is also available from this direct PDF link http://matt-e.co.uk/wp-content/uploads/2016/02/pv-final-data-V2.pdf
The results are quoted below. I kind of like it because I'm a sucker for something written up like a school science experiment but I don't really have the knowledge or experience to critique its validity
Results
The systems were commissioned on 24th June 2015 and have been left to run without interruption until the 24th of June 2016.
Final meter readings taken:
  • System 1 Non PV+ 1558.66kWh
  • System 2 PV+ 1744.97kWh
As shown in the table below both systems easily out performed the expected generation. However the PV+ unit achieved an additional 186.31kWh or 11.95% compared to the system without the PV+ unit fitted. <see the PDF for the table>
Conclusion
While the additional 11.95% increase is significant in monetary terms, especially for the early adopters on higher FiT rates, It should be noted that the test was carried out on an industrial estate where heavy loads on the local grid significantly lower the voltage during the working week. Thus reducing the need for and the benefits of installing the PV+. This theory is supported as most of the increase in generation was gained during early evening after local factories had stopped production but mainly during weekends when they are closed. It would be fair to assume grid voltages in residential areas would be more consistent during the day, therefore in areas of higher grid voltage, inverter off times would be more frequent meaning further loss on generation
I see the trial was run by the supplier - those always make me take them with a pinch of salt.
Do I read it right - the inverters shut down because the mains voltage is above 244v - nothing to do with the panel generation?
Hi weve just had a matt-e pv+ fitted too, its connected directly after the inverter on the ac output. How is it supposed to protect from over voltage if its on the ac output ???
I'm just thumbing through the manual...quiet at work at the moment.
Martin.
Q1 Did they install it within 1m of the consumer unit?
Q2 Does you voltage regularly go over 246V?
I'm just looking for reasons for you to get your money back from the robbing bar stewards.
Not only that how does you system now comply with G83 if you have a device between the Inverter and the Grid ? ....
Reply to PV+ - anybody heard of this? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hi all, long time lurker first time poster here! Was thinking recently that with the new ev charger installs taking off, and with Solar batteries...
4K
Hi All, I've been curious for a while as to how my Solar PV is doing compared to a 'typical' install. Recently, I purchased a Smappee (which is...
M
Hi All. I am new to this forum. I am a sparky whom has been largely out of the trade for 20 years, with the exception of the odd little job for...
