Take it back. Get a length or two of conduit, a coupler, 2x stop end boxes, 4x M4 screws, 2x lids, 2x gaskets, saddles and a pot of cement/glue and do the job properly. SWA has got to be one of the roughest ways to carry out this job and your more than likely end up with two unnecessary joints that you wouldn't have if you used another method like the one I've mentioned.
Cant see any reason why SWA would be 'rough'. If the joints are done properly and are internal then I cant see any reason why conduit would be preferable.
Just choose an electrical enclosure that has enough room to join the cables and to fit the gland nut securely it will also need to be able to seal the entry of a flat cable.
An earthing nut (piranha nut) will make earthing the armour easier but will still need a ring crimp on the earth tail to affix it to the nut.
If you were to clean the coating off the contact area of a metal enclosure and fix an earth connection from the enclosure to the circuit earth then this would also be acceptable, however it can be difficult to get a good clean contact on the metal box (though piranha nuts also have cutting teeth on one face to assist with this.
thanks, will go,with the earth nut.....is it ok then to use a connecting strip to join the cables in the enclosure, a 30 amp strip maybe.....manynthanks for the advice
thank you, I have plenty of YouTube and guides for the gland fitting.....I will test everything and I am a perfectionist, so will do everything properly, just can't afford an electrician.....I do my own plumbing also, but as someone ' kindly' pointed out electricity is dangerous and I can certainly understand the concern felt......I repair computers and it's scary what some people do to them ....but again....it will not kill them....thanks once again
A 30A terminal block would be a bit large for what you are intending and make it harder to get a good connection.
The boiler will be taking about 1 amp so a 6 amp terminal block would be enough but the terminals may be a bit fiddly to get the cores into.
If you have bought the proper test equipment to check the circuit this will have cost you more than employing an electrician.
I would practice fitting a gland on a piece of scrap cable first as it is easy to mess up the armour.
The test equipment required will be more expensive than the electrician to do the job!
I am replacing a 1.5 internal cable that was run temporarily to give a constant on feed to,my new boiler, as the previous one didn't require this. Unfortunately the only route this could take was from a bedroom ceiling through the floor to the boiler downstairs.
I intend running a 1.5 armoured cable from the loft area, picking up the existing 1.5 cable which comes from the airing cupboard and central heating control /pump.
Just as all the others have advised, get yourself an electrician before you electrocute yourself or someone else. You are asking too many basic questions about installation methods, without even the worry of when energise your work.
Out of interest, who installed your new boiler?
...and a course incorporating instruction of how to operate said equipment would cost even more.
....mind you, there is always You Tube :censored:
Reactions: 2 people
No but all mine is wired internally! Lol
I still want to know if the cable he has bought has enough cores - he seems reluctant to answer my question.
lol the old boiler would of had SL,N,E. New boiler would need SL, perm live, pump live, neutral, earth so probably only needs two extra cores. so would of thought the 3 core the OP has bought would be ok.
I just don't understand why a sparks would opt for SWA....The cable needs connecting to the boiler and wiring centre so got to gland the cable off either end in to a box and make two unnecessary joints in the cable.
Hum... if you are going to that extreme to run a new cable than I would probably run all the relevant cores in a single cable - but that's just me!
installing 1.5 armoured cable, need termination advice please
reddwarf4ever,
Sintra,
