Discuss Bathroom zoning question in the UK Electrical Forum area at ElectriciansForums.net
In my bathroom I have got a triple pole fan iso that is directly above the bath at a height of 2.29m or thereabouts. My bathroom gets cold in the winter, really cold. So I often turn the fan on just as I am getting out of the shower. It's also pretty damn steamy as well until it clears. I have never had the slightest tingle from this switch in over 14 years. I do actually intend to relocate this particular switch at some point as I have never been that impressed with its position, and I would not fit any switch directly above the bath in this way despite it being technically outside of zone 2. But I would and will continue to fit plate switches outside of zone 2 horizontally if the customer so wishes. Traditions do change over time...
Did a Periodic a couple of months back at a commercial premises and the male/female toilets had been knocked into one to create a shower room/toilet. No rcd protection on the shower or any of the circuits, an existing hand drier point is now for a hair dryer which is in zone 2 adjacent to the shower cubicle. The hair dryer is a standard appliance which you can actually use in the cubicle.
Job had just been completed, spoke to the powers that be who went ballistic on the phone to the contractor.
I do actually intend to relocate this particular switch at some point as I have never been that impressed with its position, and I would not fit any switch directly above the bath in this way despite it being technically outside of zone 2. QUOTE]
Why bother, it's acceptable according to the regs?
Re above, I can't get my response out of the quote, but it was;
Mid, I understand where you are coming from and understand why you have questioned my post above. The main reason I will eventually relocate the fan iso is because it is at ceiling height in a cold bathroom that gets very steamy in winter. It's location is OK according to the regs yes, but I would lean towards your stance in this instance with this particular switch.
Not wanting to paint a picture of me naked for every one (!!) but when I get out of the shower I grab a towel and stand on a bath mat when I get out. So I am pretty dry by the time I would be switching off any lights. Whereas I tend to switch the fan iso on just before i get out of the shower - hence my reasoning.
Given that I have never had the slightest tickle from the iso I would suggest that a plate switch >60cm away from the bath would be fine.
I really don't get this - why doesn't the OP want a pull switch? Fear of string? It's the perfect answer - no shock risk, discrete (unless you fit a bloody big chrome pullswitch :) ). I just don't get it. A standard plate switch in a steamy shower room is never a good idea, regs or not. Daz
Reply to Bathroom zoning question in the UK Electrical Forum area at ElectriciansForums.net
A pull-cord shower switch is located in Zone 2 of a bathroom, including the ceiling base containing the electrical connections. With a little...
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
