Discuss Water Distiller Temp Adjustment in the DIY Electrical Advice area at ElectriciansForums.net
Fife43
Hi,
Thanks for adding me to the forum. I am wondering if there is anything that would enable me to control and lessen the temp of my water distiller. I know that adjustable temp water distillers are available but would like to keep using the one I have if cheaply possible to adjust. It is 240v, 750w 50/60hz, Cheers.
all depends what he wants to distill.
chuck a bottle of voddie in there, that should lower the temperature. don't need an electrician for this.. :p
See your training is coming along well, bottle of Iced voddie cures lots of things :p:D
Hi guys I am trying to extract essential oils and as I understand it heats up too quickly.
Thanks Lee. I am not too sure what you mean by a ramp rate. Will this setup take about an hour to reach 100 deg? Is it possible to set a top temp (say 70 deg), with this? Does it need to be incorporated into the case of the distiller or could it be used if isolated in some way outside it okay? Sorry for all the questions, thanks again.
ramp rate means how long it takes to ramp up the temperature. or you can use the PID to control power to the water boiler, or to hold it at a given temperature. though controlling the temperature at 70C is not gonna help you distill water.. ?
Yes it will maintain your 70 deg set point (SP) within 0.1 degree or so. And you can dictate how long it takes to get to 70 deg by adjusting the ramp rate.
E.g. Set the SP to 70 and it will take 1 hour to heat (in your case) 70 degrees from zero. If the liquid (PV 0r process value of the water at rest) is 20 can set the ramp to 50 to heat to 70 in 1 hour or 100 for a 30 minute ramp.
I've used those cheap Chinese controllers and relays and they work quite well.
The supply to the heating element goes through the relay. The controller controls that relay and the temp probe from the controller goes into the liquid or in a thermowell that's incorporated into your vessel somehow.
Thanks Karin. I want to extract essential oils so not distilling water and the oils are very delicate, cheers.
Thanks Lee that sounds like just the ticket cheers.
...but extracting essential oils is usually made possible by distillation (or pressing), not by soaking in hot water.. ? don't mean to start going off topic, though. the PID will do the job you want, there's plenty of guides to wiring them up online, you can either incorporate it into the unit or use externally depends on the water distiller design. for these purposes it's essentially a thermostat
Yes using isopropyl alcohol to extract and the distiller to boil it off and reclaim most of the iso. As alcohol boils off at lower temp that is why I was looking to make the distiller adjustable and the oils are the delicate part so the fact that I can programme the ramp up time and temp with this device is brilliant. Thanks for the info cheers.
Reply to Water Distiller Temp Adjustment in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys, I am new to the forum so be nice! I have this ABB (now Fimer)PVS-100TL 100kW inverter which cut off if there is too much solar...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hi, I am just wondering if there is anybody out there interested in allowing me to do a little voluntary work with your company to gain a little...
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
