Discuss Never have I ever!!!!! in the UK Electrical Forum area at ElectriciansForums.net
Never have I ever ----ed in a plumbers bag, because the ---- blow lamped my newly run cables, because he couldn't be arsed to get a solder mat.
Never told anyone this before.
In his words, they will be ok, there's no copper showing and they are barely marked.
Just like his bag :rolleyes:
Lol true.
I seem to remember having a nose to nose discussion along those lines. I remember saying as a plumber, all your gear will be waterproof.
The site manager got involved and I walked.
He tried to get me back because it failed the basic tests.
The idiot had boarded up without changing the lengths.
I think the plumber was a relation of his, hence why he took his side.
Never have I lay down on the floor to reach for a cable under the floorboards only to crush my phone against my screw driver and crack the screen. ! :mad:
Never have I ever had such a belt off the HT lead feeding a neon sign as I did today.
Went to assess some lighting at a take away today.
The guy wanted it looking over and advice on some 600 commercial insert lights.
I ended up finding 15 issues with it.
All the lighting has been wired to switch on the neutral !!!
The HT feeding the neon has several twisted and open joints on its length, making the metal ceiling grid live.
Not something you expect when just doing a visual survey.
never have i ever took my hard hat off to eat my sarnies.
will you please desist from probing my achilles heel./ i'm amonty python fruitcake. these clips just freakme out.
Doodys just lost his 'V' to the Monty Python phenomenon so every second post has a reference - he's a lad he'll calm down or go chase a stick or something!
It's making Tel go all wibbly though!
As an aside the predictive text for doody pulls up doofus! Now that's funny!
Did you make the sound of surprise and alarm? :D
No, that never happens...
Never have I ever forgotten to swap the phases on the delta part of one of the motors when changing the direction of rotation on several star/delta fan motors, so it started forwards then suddenly attempted to reverse when it changed to delta. I wouldn't know, but that might have made the sound of surprise and alarm. :eek:
I'm a good electrician really! :oops:
Haha
I've once been to a job on a Sunday after the guys "electrician" (to be fair it was a good job so far) where the spotlights kept tripping and he couldn't figure it out after spending Friday until 6 tearing his hair out (And the wall for a screwed cable)
So I take a peak inside the board... he disconnected it and I saw the neutral long enough to go on the opposite RCD. Sorted :D
Also tried to be converted to be a muslim. Had to politely decline and obstain from religion :D
You've just reminded me of an incident about twenty odd years ago..
Friend of mine who's also a spark. Fitted an outside light for a guy who played in the same pool team. It was a quick job..
Unfortunately the light kept going on and off when it felt like it.
So we both went to look at it ( we had nowt better to do and he only lived 2mins from the pub).
Long story short...he had cut into a cable fed from his room stat... So it went off when the boiler went off..it was funny and embarrassing for him.
He still hasn't lived it down.
But I constantly get asked "has that radiator come on yet? Just put your hand on it and see"
Be much easier with a light to signify.
Never have I ever spent 3 hours trying to put up Swedish flat pack furniture and still not finish it at 1 in the morning on a bank holiday Monday.
Never have I ever esembled it wrong (a few times) only to realise when it comes to a later step and have to take it all back apart.
Never have I ever accidentally dropped my favourite cutters down the cavity at a fire station and was forced to carefully knock out a breeze block at low level to retrieve it.
Reply to Never have I ever!!!!! in the UK Electrical Forum area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
So there I am up an aluminium step ladder with padded feet. And I'm helping my son's best friend to put insulation in his loft whilst pulling the...
NICEIC Certification Scheme NICEIC Complaint? Waste of time.
Honestly... I speechless at this story. The NICEIC have just washed their hands of a valid complaint. Ever heard of a new build property with...
13K
What is the oldest dimmer switch you have seen in use recently? When did you install your first dimmer? (Veteran sparks only) I ask because a...
