Delboybully
I did a job recently changing some faceplates. Owner was concerned about insulation above his new spotlights. Over some the insulation wasn't put back at all - a whole section was moved and not put back. Other spotlights had been covered. Also no jbs used so inner cores exposed and no cert. Took the guy 3 days to put 14 spots in 3 rooms, one external light and one external socket. The so called sparks promised a cert but nothing turned up.
Customer supplied the spots and external light and socket. So called sparks supplied everything else and labour for 350
I ended up sorting the mess out and the customer realised that the cheapest isn't always the cheapest and was out of pocket.
