Discuss Minor Work Certificate in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon all,
Just newly qualified, so not registered with recognised body to do self certs. So having new kitchen fitted, and existing sockets in old cupboards just needed fitting into new cupboards. Fitter insisted that he needed a MWC so another sparky fitted sockets and raised MWC, total of £60. Is this right, as from what I can see, there was no alterations or addotions to existing circuit, so did it need MWC...or am I being 'special'?
There were alterations to the circuit, albeit very minor, a MNWC is required, refitting sockets and a MWCert £60 not a bad price, how long did it take him?
Changing accessories does not warranty a MWC.
A test for Zs and note on cert.
Ah but is he or has he just changed the accessory? he may have had to extend / move cables to fit the sockets into the new cupboards, I'll stick with a MNWC.
It took him about 15 minutes, including direct Zs test. Fair enough, I just wanted to confirm. Thank you.
To get the right perspective on this job, and to settle argument of whether a MNWC is was required, was it a cas of just changing the face plates, or was further work required, extending / moving cables etc? for the OP to answer please
BS7671 notes on MEIWC, say this certificate may be used for replacement of accessories or luminaires, as well you know :)
I read here that some of the larger suppliers of kitchen & bathroom units, require certification for the simplest of things.
Personally, the replacement of one accessory, I do what Murdoch suggests. Anything more I tend to issue minor works.
Recently, I had one old customer contacted me. They were selling their house, where we had refurbished the bathroom, a couple of years back. I had just replaced existing extractor fan & associated isolator (not in Zones). But I did a minor works. Their solicitor wanted copies of 'certificates'; it sometimes just makes life easier.
Sounds like sockets mounted in old kitchen units got removed then re-mounted in new units once installed.
I the OP doesn't come back with an answer we will never know will we? but from the OP's original post I will still go with MNWC
We seem to be debating a minor issue here, excuse the pun. I agree swapping like for like doesn't necessarily mean a MNWC is required.
Either way the client has a record that, accessories were changed, the client will no necessarily appreciate what work has been needed to swap these face plate, so in essence are we just arguing over who is right or wrong here, there are differing opinions, as there always will be, but in the grand scheme of things, no one got hurt the client has a record of what was done and when, so really no big deal, but I'll still opt for the MNWC.
MiNor Works Certificate or a Minor Electrical Installation Works Certificate. Till the IET come up with something else just as complicated, for what it is something so minor, its just not worth arguing over :)
A loop & RCD (min test) takes minutes.
Hoover, vacuum cleaner, PAT, ISITEE.
Same thing different names.
I just thought I'd ask as it was a new one on me.
So, to answer the questions posed above:
No cables were moved / re-routed (unless you class the hole in the unit as a re-route but was to original position. I'm the client and I would have been happy having just newly qualified just refitting back into cupboards. It was the kitchen fitter who was insistent about certification. Which I understand but there were no modifications or alterations. Can't wait to get registered with accredited body.
Some of the Joiners, kitchen fitters, plumbers etc I work with are the same.
They want someone they trust to do the work and issue paperwork as it is part of the overall job and ultimately any problems could adversely affect their reputation in the future.
£60 in the scheme of things is nothing. :)
Of course in BS7671, notes on Minnow Worrying Credential (MWC), suggest the person ordering the work should receive the MWC and pass a copy onto the owner of the installation. Perhaps the kitchen fitter been spending lonely nights, reading BS7671, to try and solve his insomnia. :D
If this was just alterations and no new circuits, there is nothing stopping you (newly qualified) doing the work yourself and producing the MEWC (Minor Electrical Works certificate). The work you have described is not notifiable and therefore you don't need to be a member of a scam (registered scheme as you called it).
Jay
Reply to Minor Work Certificate in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi everyone, I’m brand new to the site and hope everyone is doing well. My question is this: I have a 2365 level 2 diploma and have been doing...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Evening all, Pretty straightforward I think. I was led to believe that surge protection needs to be fitted on all additions and alterations...
4K
