Discuss Hive my old thermostat in the Central Heating Systems area at ElectriciansForums.net
I have my new hive system up and running but want to take off the old thermostat which is set at 30 degrees as the hive over runs it. I want to put the wireless hive in the same place as the old thermostat but don't know which wires to join and which ones to just leave or cover. I know its not good practice to do this but I want to leave them there in case I leave so I can put the old thermostat back in situ. Ive took a pic of the inside of the thermostat.
Put 1 & 3 into same wago/choc block. Put 4 into its own wago/choc block.
Should have run a stanley knife around that stat before you pulled it and half the paint off with it though[/QUOT
Thanks for that yes I know I messed up lol but hopefully I can find some extra paint before the mrs notices lol
Reply to Hive my old thermostat in the Central Heating Systems area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hello, I'm in the process of changing my wired remeha thermostat with the wireless hive mini, I've had a look at the manual and believe I have...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
