Gavin John Hyde
Patron
Jun 4, 2017
3,811
5,857
3,541,381
Somerset
www.sulis-electrical.co.uk
Business Name
Sulis Electrical Services Ltd
I have a ring circuit (circuit 1) and a light circuit (circuit2) in a flat im working on and i have somewhere in the walls or ceiling a joined earth path. From what i have seen there is no obvious metal conduit, so it seems its either the ventilation system that is fed by the same ring and goes to each room near the light circuit in question or one of the metal stud parts on internal walls.
I have tested between them and confirmed at light points and sockets that a path exists. I have added in a new shower circuit and extra sockets and some downlights. it was by chance i clipped the wrong earth when i had them out in the cu for the EIC that i discovered the shared earth path.
It is only between these two circuits, The flat is part of a newish building around 3 years old and is made mainly of a wooden frame and structure with stone cladding. There is some metal stud work but most of the building was modular and delivered in sections to be put together. think of it as a giant kit house.. I have put an endoscope in the voids but not seen anything as yet that is 100% the linked path. There is one water pipe around 2 metres in length entering the flat then the water and heating are all plastic pipes. with the boiler outside the flat door in a cupboard.
Given the nature of the building its not wise to start pulling bits apart and making holes into wooden joists etc..
Its clearly been there since it was built.
What would you put on certificate to indicate this... I have put so far ... shared parallel earth path between circuit x and y. location not known due to nature of building.
Any thoughts or advice
Parallel earth paths are common in existing installations. It's not even worth time looking for it.
It hasnt stopped me taking the tests I was merely checking whether to record it or not, given it was such a new installation i was a bit surprised to find one. Come across plenty in older homes not many in new. my only real concern was the possibility of joined circuits on line and neutral but i had ruled that out already. so just peace of mind really.
(Had a thought if it was a " helping hand " by design ,
may be near furthest point in lighting circuit ! )
It's common for CPCs to be interconnected for whatever reason, be it by design or by accident, think supplementary bonding. Seen CPCs joined at the end of circuits to bring down Zs of both as well.
Could be supplementary bonding or both the metal boxes touching metal stud. Take it the insulation resistance testing was ok? I would do a R1 +R2 test on both circuits removing C.P.C. from earth bar.
Most houses will have it on upstairs & downstairs lighting circuits if a multigang switch is used at the foot of the stairs.
I think the most common interconnection is between upstairs lighting and boiler circuits.
Why so ? Sorry if I'm being dim, ready for a break !:)
all tests come out okay. its linked somewhere within the structure of the flat, unlikely to ever find out where,
Bathroom supplementary bonding.
A 3 year old installation would have RCDs and wouldn’t need supplementary bonding in the bathroom.
It would only need a 2+1 box with a light switch and a socket in it to create a shared earth. There’s all sorts of possibilities.
They are all common at the CU.
Reactions: Risteard
Gavin John Hyde
Patron
Somerset
Website
http://www.sulis-electrical.co.uk
Business Name
Parallel earth path between 2 circuits
Gavin John Hyde,
Gavin John Hyde,
