Discuss Dual Tariff or dual RCD in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone
I currently need to change a dual tariff (economy 7 & on peak) consumer unit situated inside a flat.
One half of the existing split fuse board serves the storage heaters with the second separate half being the On peak supply.
Am i correct in thinking a standard dual RCD board is effectively a dual tariff DB.
Just making sure i am not being a numpty in my thoughts? which is quite often the case.,
This is how we do it place the offpeak tail in the last rcd then link the main neutral
That earth is a classic for bye anything else.
The yellow, black, red and blue look like they are swa cable which is floating behind the board. How long before the black lashed into the main switch starts giving smoke signals. If one of our lads did that we would sack them.
Must admit , it is well populated.
Yeah you are defo right there I will defo bring this up with the firm I work for.
You also should mention
● Conductors not enclosed into the dist board.
● Correct identification of the swa conductors.
● The yellow conductor is oversized to enable suitable termination at the earth bar and hence strands have been cut away.
● Generally all conductors are poorly terminated especially the secondary neutral at the main switch.
● The consumer unit has been altered beyond manufacturers recommendations.
and I may has well put ,that neutral to the rcd side to the s/heaters not marked up for the line .I have seen a lot like that .
Reply to Dual Tariff or dual RCD in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
