- Reaction score
- 7,782
I am now checking for any parrell paths so here it goes up stairs ring cpc r1. In board in r2 wander lead mothod testing to boiler 23.6 ohms and all pipe work the same . water service disconnected and gas .any thouhts
Discuss Now i am pulling my hair out in the UK Electrical Forum area at ElectriciansForums.net
possible that a metal soil pipe is buried in the wall that's what I'm thinking. .connections. With 23.6 Ohms it sounds like there's "an earthrod" attached
common brick .Buzz, what sort of walls are the metal back boxes fixed in?
what sort of building is it?
not if the earths are connected to the c/u ,but showing earths on sockets in brick walls . and cables under wooden floors and not touching any pipe work. I have checked for that .even up stairs socket showing earths where present .Surely its as simple as something metal, probably the incoming cold water pipe, connected via other pipes to an earthed metal appliance. Very easy to prove too.
looked under the floor boards ,Are you sure building is not old enough to have - underground "Panic Room" / priest hole !
" Stealthy alarm system install ".
Been in attic yet?
Has it ever been the home of a radio ham or a DIYer
fearing a lightening strike !
Reply to Now i am pulling my hair out in the UK Electrical Forum area at ElectriciansForums.net
