N
NA Radium
Hi all,
I am new to this forum so please bear with me. I am seeking advise on the do's and don't in regards to using an inflatable hot tub.
Please be aware that my options are somewhat limited as I am a private tenant.
The hot tub has its own in-line RCD rated for 16Amps and the manual states it draws 13Amps as a minimum!
I have checked the circuits and we have upstairs and downstairs sockets on separate circuits rated at 32Amps.
The complication I have is I don't think the lead from the pump will be long enough to reach to the nearest socket in the conservatory, could we get away with using a heavy duty extension lead?
Edit:
I have found a digital copy of the manual should it be useful and it mentions extensions leads should not be used
. Also I believe the cable from the pump is between 3-4 meters long.
[automerge]1585687931[/automerge]
Edit:
