chadtoth24
- Reaction score
- 0
I am a very knowledgeable DIYer with no issues on any beginner to intermediate wiring because my father is a retired electrician.
The issue:
I have a safety issue I am concerned it might be an expensive discovery mission if I hire an electrician early on so trying to narrow down to am easy fix or a hire with resolution. I have a hot tub that never had issues until recently. I happen to be barefoot outside the tub and touched the water and felt current. Not horrible but uncomfortable. I only feel it if grounded. Had been in and out of tub for who knows how long using mats and never had an issue until the mat was removed. It was then I first noticed.
The facts:
The 220 runs under ground to a exterior ground fault close by the tub which then goes back underground all the way to a 200 amp panel. It has a dedicated 60 amp breaker in the panel. Pavers is what surrounds the tub base. I originally did all the install. Again, never had an issue for past 4 years.
Thoughts:
I feel like there is a grounding issue but can't be sure. I also wonder if the charge is coming from another open wire nearby or something. The tub gfi isn't tripping so I feel like the issue might be another wire or maybe my gfi is old. I tripped it so it does work. The only changes between before and now was 6 months ago, hot tub mechanic added a new pump motor and maybe that is the issue. Could that be sending a current through the water? Again, because of the artifical turf mats acting as a ground barrier, I can't be sure when this started. Any ideas. I can take pictures of any and all. Thanks for any thoughts.
The issue:
The facts:
Thoughts:
