M
missin44
I would like to set up my hot tub wiring a few months before my tub arrives, I would also like to do it DYI. The run I'm panning is 100' from the main panel to the tub. The hot tub (Bullfrog) requires 240v/50a service.
My plan at this point is to install a 50 amp breaker on the main panel with a 90' run of 6AWG to a hot tub sub-panel, the sub-panel would have a 50 amp GFCI breaker, then the remaining 10' to the tub with 6AWG. All of this would be run through 3/4" or 1" PVC, galvanized, or flexible conduit. Due to the rocky terrain only about the last 8' will be buried.
My questions:
My questions:
- For the main panel is a 50 amp breaker ok, or maybe a 60 amp?
- Is a 100' run ok with 6AWG?
- Any thoughts on conduit type?
- Am I missing anything?
