Discuss pir sensor in false ceiling in the Lighting Forum area at ElectriciansForums.net
I know fire rated downlights are installed in false or suspended ceilings as the normal as the cost difference is small...
But what about PIR sensor in a false ceiling or a suspended grid ceiling wouldn't they need to be fire rated if it was a fire rated ceiling?
a suspended ceiling is not a fire barrier. fire rated downlights also are not necessary, but are probably fitted solely because they tend to be of better build quality than non fire rated ones.
It's a good question. Only applies to ceilings that are fire barriers as has been stated, but there are plenty of scenarios that would apply.
I've just had a look online for fire rated PIR sensors. I found a one by JCC, no longer available. And another one that can be made fire rated by buying an add on.
Of course, you could just use a surface mounted PIR sensor, which would not need to be fire rated.
If you surface mount a sensor on a fire rated suspended ceiling the cable will penetrate the barrier which would require fire sealing so the performance of the ceiling is not compromised.
Reply to pir sensor in false ceiling in the Lighting Forum area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Sensors are all around us, from the automatic doors we walk through to the motion detectors that turn on our outdoor lights. But how do these...
