Discuss Earth terminal block in the UK Electrical Forum area at ElectriciansForums.net
It is not the answer to your question - sorry - but there are 9 in stock in the Calais shop you provided a link to - which is not far away. They have other shops too.
Yes, its for an existing installation with a very awkward route, just seemed as though it would be simpler, but looking at this a bit closer, the earth's out of the service head are only 10mm?
How will the open sided connection help with an awkward route?
A line tap will allow you to connect to an unbroken cable, and be more reliable than that dodgy looking block in your OP
Just take my word for it.
Looked at line taps and can't find any at a reasonable delivery charge, do you have a link to a any?
I don't just take the word of any faceless stranger, I'm not daft. Plus saying that just makes it sound like you are doing something non-compliant and hiding it.
TLC sell line taps as far as I can remember
Nor am I daft and don't have to explain myself to anyone who answers a question with a question. And I am not doing anything non compliant. Dam & Blast I just explained myself. :eek:
I thought I was quite clear in my first post, I am trying to find a multiple connection block that can clip onto an existing cable and have other cables attached to it. I do realise that because lots of us have time on our hands it's very easy to get a bit pedantic, but I am just a simple fellow and say what I mean without a hidden agenda.
[automerge]1586954504[/automerge]
Just solder to it.
Good option, but I have multiple connections needed onto the existing earth cable.
Perhaps I'm wrong it was so long ago I last saw one of these, but I'm sure that's the reason the plastic is open at the back of the main terminal.
I believe this one from RS allows connection to a continuous main conductor, IIRC the bar at the bottom slides out when the terminal is loosened.
Freddo, its actually the large terminal that slides off when its loosened, the only problem with it is there is no provision for fixing it to a back board, may have to use an earth clamp. :yum:
What does this mean? I'm trying to put up a light and have been told there's only 2 wires in the light which means I need a separate earth terminal I bought new chrome light switches, got a so called electrician to change them over, he fiddled about for an hour then said he had to go, he left me with the same light I already had up, didn't even attempt it actually.
The hour was taken up with him changing the light switches from the white to Chrome, but now the light doesn't turn on at all. Never put a light up in my life, I'm going to try, please can you tell me what a seperate earth terminal block is. The instructions say I need one.
Would there already be one or is this something extra I need to buy?
Hi @Daisy90
You'd be better off starting a new thread with some pictures. It's a very different topic to the one this thread is about.
One tip right now - before you try and change the light, focus on getting the switches working again.
and post an approximate location. 1 of us may be close to assist.
Reply to Earth terminal block in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
