Discuss 1930's clock rewire required. in the UK Electrical Forum area at ElectriciansForums.net
If it needs tlc in the sense of electrical safety, then a willing electrician could be just the person to deal with it.
If it needs tlc to its workings/ gear train/ hands/ etc. (eg it doesn't go) I don't feel an electrician would be the preferred candidate (Petej999 excepted), unless they happen to be horologically inclined 🤪 (speaking as someone who is, but doesn't do repairs!)
Try one of these if the clock is worth repairing:
Electric clocks are cool! Here is the last one I restored, it now lives in my kitchen. Gummed up mech and open circuit motor coil. Damn that winding wire is fine! Totally silent running which is nice, no annoying tick, tick, tick...
I think I'd swap an annoying tick, for an even more annoying cable out of the top of it though
What you needed was an Avo coil winder
or maybe you used one?
The break was 2 turns in so just reattached to the terminal. Had to use tweezers to handle the end of the wire.
I'll wire a clock point in when I finally replace the kitchen.
Reply to 1930's clock rewire required. in the UK Electrical Forum area at ElectriciansForums.net
I accept this is an unusual post! This clock has been in a family since early 1930's, the owners grandfather acquired it and fitted it for his...
I qualified as an electrician using the C&G 2330 route back in 2012... I stayed in my current job which is non electrical so I spent 3.5 years...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
