- Reaction score
- 986
good video from Pen explaining the new amendments including AFDD,s
Discuss Amendment 2 13 new changes! in the UK Electrical Forum area at ElectriciansForums.net
In the case of me extending an existing ring circuit for instance Which has an existing AC type RCD in place, this would therefore not need replacing with a type A RCD?I would think that it's not mandatory to replace an existing RCD, same as it's not manadatory to replace a plastic CU . Anything that you fit should comply with current regs., but even 3036 fuses only deserve a C3 provided they are in a safe working condition.
I would guess it comes down to the same sort of C3/C2 risk for a lack of RCD so for sockets inside the house that are not likely to be used outdoors then not a high risk.In the case of me extending an existing ring circuit for instance Which has an existing AC type RCD in place, this would therefore not need replacing with a type A RCD?
Reply to Amendment 2 13 new changes! in the UK Electrical Forum area at ElectriciansForums.net
