M
M1kbee
All of my upstairs lights have stopped working.
All of the plug sockets both up and downstairs are working and the downstairs lights are fine.
The consumer unit seems to take what look like cartridges roughly 1" x 2.5" / 25mm x 65mm with coloured dots on them.
White - 5amp
Blue - 15amp
Red - 30amp
Anyone got any ideas what's going on?
You can try swapping the two 5A fuses. If it was a one-off fault like a failing lamp you will find the upstairs work and downstairs no longer. If the fault is still present then unfortunately you will have no lights and two blown fuses!
EDIT Make very sure the power is switched off before you remove or insert any fuses!
If there is no change then probably a wiring fault needing professional help.
If it is one-off due to a failed lamp, etc, then just a new fuse like @UNG has pointed you to.
I'll give it a go tomorrow and see what happens.
As above, there should be a length of fine fuse wire linking the two brass pins, going through the ceramic middle section.
If the fuse has blown that wire will be missing (or maybe two halves with ends showing solidified molten metal). Replacement is fairly easy if you have the correct wire (you can usually buy cards with 5/15/30A wire on them) and a small flat-blade screwdriver to loosen the screws that hold the wire in place.
M1kbee,
Petej999,
