Discuss Wiring of Talento 211 in the DIY Electrical Advice area at ElectriciansForums.net
Raphael
My problem is that my Talento 111 time switch has stopped functioning. It seems the Talento 111 is no longer available but the 211 is so I bought one only to find that the connections are not the same as for the 111. I need help with the correct wiring for the 211. I attach pics of both
I can see no difference between the two pics, right down to the time on the clocks.
You are right, apologies. I attached the same pic twice (eye test tomorrow, coincidentally).
Having another go. Just wanting to know which wires go where in the Talento 211 compared to the 111.
1 and 2 on the old are N and L respectively.
3 on the old is 2 on the new.
4 on the old probably goes to 1 on the new, but I can't say for sure, as there appears to be something pink (a finger?) obscuring where I'd expect the diagram to be.
Thanks very much for that, Brian, it really helps me get this switch installed. I’m sorry that the photo wasn’t as clear as it needed to be. I’ll take a couple more shots of the old switch tomorrow in the hope that you can definitively tell me where 4 goes on the new switch because I don’t want to risk damaging with an incorrect connection it since it was a pricey bit of kit.
If you put the old 4 into the wrong one of the two places it can go, all that will happen is whatever this controls will be on when it should be off, and off when it should be on.
Thanks again. Good to know I won’t blow it up. Trial and error should get me going again. Great forum this. How did we manage before the internet!
Reply to Wiring of Talento 211 in the DIY Electrical Advice area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Novice here wondering what I might be missing. Thanks for any help. I am swapping out an old switch in the bathroom to a dimmer switch. When I...
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
