Discuss Boiler fused spur in bathroom enclosure? in the UK Electrical Forum area at ElectriciansForums.net
How about an IP rated one that can be padlocked off ?
What do you mean by a “boiler enclosure”?
Is it in a room off the bathroom with a substantial door, or within something like a kitchen cabinet?
Reply to Boiler fused spur in bathroom enclosure? in the UK Electrical Forum area at ElectriciansForums.net
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Has anyone come across click accessories spurs burning out? it seems to only be happening with the CNS200 Trend uk Steibel eltron heaters Fuse...
Hello, Is it a requirement to provide a fused spur to a gas boiler? Or is a single socket okay? The boiler is in the garage. Thanks,
Hi folks. Need some help, wanting to add bathroom mirror with built in shaving port but don't want to chop into wall as I can't replace the tiles...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
