- Aug 12, 2017
- 14,335
- 20,734
- 3,557,381
- 51
- United Kingdom
If properly designed to class 2 requirements, the risk of a fault from the fitting is (should be!) minimised.I see. So the view is that the risk of a fault energizing the cpc -> appliance outweighs the risk of a fault in the fitting energizing the small metal plate.
Just because something is “made in China” does not necessarily make it low quality….
