Discuss Help! Fuse board gone nuts - lights flickering on and off. in the Australia area at ElectriciansForums.net
drjarmin
My electrician that wired up my house is on his hols so, although I helped, I am not a qualified electrician (which will become more than apparent) but hope someone can advise as I can't get hold of him. I think this is a simple issue to an expert.
First noticed an issue as the lights in the house started to flicker intermittently.
Went to the fuse box and can hear a noise coming from it. It seems when any significant amount of power is drawn, there is sparking on the newtral return bar (see picture).
The screws are tight so there should be a good connection. This set up is about 2 years old from installation.
I have shut down ALL circuits except for the fridge. Any advice please? Thanks.
Could it be down to oxidisation stopping a good connection? Something as simple as that?
Was this a recent rewire?
I'd get somebody in to take a look - where are you? I'm certain that there are many sparkies here who would be willing to pay you a visit!
Is this in the uk or europe ?
would say its a bad connection on the neutral bar you really need to think about replacing the whole board and the incoming tails as looks from the pictures a bit of a bodge
New fuseboard and complete rewire installed about 2 years ago by a UK qualified electrician.
I'm in a remote part of Hong Kong - hence the panic and difficulty getting hold of someone. I'm not putting the a/c on for fear of putting any load on the circuit and its a bit hot and sticky here at the moment.
The sparking under that (corroded looking) screwhead must indicate a bad connection? But the screw is tight or am I missing something here.
Thanks!
Hello Hasel5
In what way would you say it was a bodge? What is the issue with the tails? They look dirty but that is just mould which gets on everything after a couple of high humidity summers.
I suppose the bigger question - is this safe to last the night? As mentioned, I have shut down all the fuses except for the fridge as nowhere to put the frozen stuff. Seems to have stopped sparking.
Thanks.
Best advice would be to get another electrician in asap!
That's a good start.
Unlikely to be oxidisation, could be a number of other things. Don't do it yourself, get someone in who can test it! You never know what else they may find :)
That's not a neutral bar... Someone's used the earth bar as neutral. The bit "buzzing" is where you test Ze if it was still an earth bar..
Where are the earths teminated? or are they all SWA and banjos etc?
turn off main isolator. undo the suspect neutral connection. cut away the dicoloured end. and strip insulation about 10mm. reconnect in N bar ( if the one it came out of is "burnt", connect into a spare terminal. refit cover and re-energise.
Reply to Help! Fuse board gone nuts - lights flickering on and off. in the Australia area at ElectriciansForums.net
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hello, I added a 240v insta hot water heater at the kitchen sink. When the water heater is in use the lights in the adjacent dining room flicker...
Hi Guys Looking to see if anyone has had the same issues. I went to a tennanted property last year where the house lights were flickering and all...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
9K
