Discuss sockets and light switches Heights from finished floor in the Electricians' Talk area at ElectriciansForums.net
R
riosax
Just trying to confirm on a new extension of a domestic property what is the minimum and maximum heights for light switches and sockets to conform to the 17 th edition of the regulations ??
new heights apply to new extensions 1200mm top of accessories or 450mm bottom of accessories
rewires cant be no worse than they were before rewire
Don't apply to extensions...
@riosax -- Switch and socket heights are nothing to do with the 17th Edition Regs, they are a building regulation (Approved Document M)
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADM_2004.pdf
Thanks Guys, just needed clarification as architect drawings and notes from planning requested all work re the extension to be to BS7691 17th edition and re-wire of existing property to be no worse than before as stated above but client insisting 1300 for the bottom of light switches so it should be cool,
thanks
Alan
Reply to sockets and light switches Heights from finished floor in the Electricians' Talk area at ElectriciansForums.net
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi, I would like to add a new socket in the bedroom. Current room configuration: 3 existing sockets - wiring coming from the bottom (under the...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
