Kate,
just as a quick sanity check: do you know if the arrays on each of the roofs are on different strings from the inverter? The 4000TL has two strings (AFAIK) and each has an individual MPPT tracker. If one roof was suffering from low light it would not affect the other and you would maintain a reasonable overall harvest. If, for some reason, it was wired such that the two strings were distributed across each roof I could imagine that this may cause the lower energy.
The other consideration is the amount, if any, of shading. While there may not be any hard shading due to telegraph poles or dormers, do you get any diffused shading as a result of distant trees or trees with an open structure? Hard shading is bad but diffused shading, as I think I am conclusing through reading posts on here and on other forums, can sometimes have an even worse effect.
Ian, Thanks for your response to my query. Yes< is am pretty sure that it has been set up as two strings. There are separate DC isolator boxes beside the inverter clearly marked 'east' and 'west' and , when you tap the screen to light up the display,it flashes voltag/amps with a visual for 2 sides of panels. I'm sure you know what I am talking about!
As far as shding is concerned, there is none but on both sides, the sun is getting so low now that it sort of shines a glancing blow if that makes sense which is why, right now, I am regretting not overruling all advice(from 4 firms) and insisting on a string of 6 (all that would fit on hip roof`) on south facing roof, with its own inverter, plus a further whack of however many ~I could grt on either east or west, again, with a searate inverter. I suspect that the east might surpass the west.
As I said to Richard, you can only work with what you have got and perhaps come spring, when the sun is over the ridge again, my system will clock in early, fly on both sides in the middle part of the day, and clock off late: that was what I was told by all. In the meantime, it seems I will have to just put up with low production although when compared to outputs from Gary for the same dates in Norwich, there seems to be more than a 15% loss for being e/w. I will try to get figures from Sunny Explorer and post them for comparison.
Also, slightly concerning , on Saturday(22nd Oct) probably the sunniest in the last few days, we were away in Reading for the day and when we got back and I looked at the SBeam, it showed a weird drop out for a couple of hours. I queried it with my installer who has promised that the electrician will come and see me as soon as he can but having read the thread about compatibility issues with Sanyo/SMA, I wonder whether this may be happening too. On one of the other days, it also showed a sudden weird spike over the max capacity of our system and likely impossible especially at this time of year. I will try to get screen shots or photos but the technology may just beat me.
Probably not worth worrying too much at this stage. Will have to let them take down scaffold and live with it for a few months, see what happens come spring and summer. If it still seems to be underperforming, I am fairly confident that my installer will address the issues.
