Discuss Shower switch in airing cupboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
depends where the airing cupboard is and whether trhe isolator is used purely for isolating or as a switch.
well, i really like my steak rarely done
i am good arnt i spin london , have you kept tabs, have i came along way from first comming on this a year ago;) i shall fill your shoes if you pass away, hope you dont but shall!!
Well check the zones to be sure, I don't have a regs book in front of me or I would check for you. I would imagine that if you leave the switch in the on postion and don't attempt to switch it off or on from the bath/shower or when touch anything conductive in the bathroom you'll be ok.
If it's outside of the location, then there are no zones.
Reply to Shower switch in airing cupboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone My mira power electric shower is not doing anything when i press the power button. There is no led lights to check on the unit to...
A pull-cord shower switch is located in Zone 2 of a bathroom, including the ceiling base containing the electrical connections. With a little...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
