Discuss Tesco Solar! does anyone know which inverters & panels they install? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
matt25
Hi, I was wondering what kit tesco install, does anyone know? they are currently offering 3.92kWp for £6800.00 inc vat.
that's the list price. We've come across a few people who've had quotes from them that are nothing like that once they actually get the quote, and nobody so far who's actually had that quote (though a small sample size).
Ditto. It's easy to give a basic price and when the surveyor comes round he's bound to find a reason to jack the price up.
Do you reckon them Value ones are blue and white striped?
Yup. Yield would be good too I reckon, if it wasn't for the label
They use SMA,Fronius and Platinum inverters with a mix of sanyo,sharp and yingli modules with schucco mounting systems. Tescos is run by Enact Energy from Cornwall, they also do Marks and Spencers as well.
Last installer I knew that were installing for them was using Schletter and Sharp Poly, then ET with SMA & Schletter.
I have done over 200 installs for them all over the south west, as well as remedial work on other installers work and they offer a range of suppliers. Their installs have ranged from two bed semis to mansions in surrey. They dont have a chosen supplier/manufacturer.
Sweet, when can you fit 16 Sanyo and and a SMA3600? I have a cheque for £6800 standing by.
Reply to Tesco Solar! does anyone know which inverters & panels they install? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hi I currently on a job where the garage is having an office built above it with solar panels installed on the roof. I have ran a 16mm 3 core...
Hi. I've recently passed an EESS course with LCL snd just done my first inverter and battery install with parts supplied by the customer. My...
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
