- May 31, 2009
- 550
- 240
- 118
- United Kingdom
- Business Name
- Absolute Electrics & Audio Visual Systems Ltd
i run an NICEIC firm. i went to a house the other week to quote for some work in a house that some people had moved in to recently. i noticed that the fuseboard was new and an NICEIC registered sparks had done the work and some other wiring in the house. there were stickers on the board.
Anyway we got the job and started the work only to find that there was no CPC on the lighting circuits (even though the previous sparks had earth loop readings for the circuits). the ring circuits were not continuous even though there were end to end results for the ring circuits, and worse of all the new lighting circuit had metal accesories fitted and the light switches were not earthed. the CPC was just loose in the back of the box with an extra long length of sleving on it.
two of us spent till 11am tring to ascertain whether we could do any of the work that we had priced for but alas we could do anything.
i informed the client that she had recourse through the NICEIC as the electrician who had carried out the work was registered.
she called the NICEIC and they said the following:
1. she was not the person that ordered the work
2. the work was carried out over three years before
on this basis the NICEIC would not investigate.
Now since when does an electrical installation suddenly become safe after 3 years? and if this is the policy of the NICEIC why do completion certificates last for ten years and not three?
it seems to me that the NICEIC have completely lost their way. it is an utter money grabbing con.
Menawhile the sparks who did this work is still registered and still doing crap work like this.
