Discuss pir's operating two circuits in the UK Electrical Forum area at ElectriciansForums.net
R
Richispark
hi guys hope all are well,
I am looking to wire 17 lights over 60m either side down a driveway from 3 pir's but only have 2.5mm and 1.5mm singles. im wondering how I can wire both sides of lights as they are two circuits but both operating off the same pir's?
thank you
Generally I wouldn't design a circuit according to the cable or wire sizes I have in stock.
I'm not entirely understanding the layout you have but it sounds like you could do it using a contactor or two.
Reply to pir's operating two circuits in the UK Electrical Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I needed to illuminate our dark side walk at the house. I have used two PIRs wired in parallel which switch four LED lights. The idea is no matter...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
