- Feb 12, 2012
- 139
- 113
- 118
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Electrical Enthusiast (Unqualified Hobbyist etc)
I'm in Azerbaijan so UK regs don't apply but safety and common sense do.
My house has a 3 phase supply to the main CU, which then feeds 6 other CUs around the house - one on each floor, one for aircon and one for garden. The incomer is 3P+N, no earth. I have two earth rods in the garden.
We sometimes suffer voltage drops, so I decided to put three panel voltage meters in the CU front panel so I could see what was going on. I intended to just use a spare 3P breaker on the CU to connect them. Trouble is, the breaker takes cables up to 10mm (at least) and the wires for the volt meters are a few strands thinner than a human hair. How to make the connection?
