C
cherylleack
Hi all,
I have quite an old Horstmann Economy 7 Quartz water heating system in my flat (installed around 2007). It's been working fine until the last month, now the water heater always seems to be 'on'. The clock is set to the correct time, and even when it is the middle of the day when the heater shouldn't be on, the neon off peak indicator light is on and the water is still being heated.
The only way to stop the heater is to switch the water heater to 'off', when the switch is set to 'timed' the water is constantly being heated no matter what time it is.
Is this a problem that can be fixed? Or does it need replacing? If so, does it need replacing with the exact same controller... it is quite old and I'm struggling to find the exact one, I'd like to avoid having a whole new system installed if possible!
