Discuss 1652 Fluke Voltage error in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stidge
Hi all, RCD test today on multitester,1st ring fine,2nd ring ERROR 4 which is a voltage fault.Voltage was varying from 240 to 285 but couldnt find any problems Any Ideas Please????:confused:
Did you recheck your first test to confirm meter is still OK? Where were you testing the RCD? on the wiring or at the RCD terminals? I.E were you using the plug in lead at an outlet or probes at the RCD.
Cheers.......Howard
Reply to 1652 Fluke Voltage error in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hi, I've got a light with a ceiling rose in the kitchen. While rectifying some faults in the house I came across to the light and measure Neutral...
5K
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
