Discuss 2.5mm2 Ring Final Circuit vs 4.0mm2 Radial in the UK Electrical Forum area at ElectriciansForums.net
I recently read an article about the advantages of both the RFC and Radial circuits, after which I must admit that I am more swayed towards the Radial.
What are others thoughts? What do you prefer and why?
Being an old timer, and most of my working life I was in favour of the Ring Final Circuit, or ring main as it was known, and still is by some of the electricians working today. I helped out on a rewire a few months ago and saw the advantages of the Radial final circuit, so in a nutshell if I was still on the go I would opt for the radial, if the conditions were right, hope that helps.I recently read an article about the advantages of both the RFC and Radial circuits, after which I must admit that I am more swayed towards the Radial.
What is it particularly that swayed you?
Main disadvantage of a 4mm radial is that if you want to add a spur at a later date, to anywhere but the CU or last socket it'll be dammed hard to fit in 3 x 4mm cables into the majority of sockets, let alone the big shed ones!
I could be wrong in what I'm about to say, but if you take a look at appendix 15 it looks to me like they are saying that you can if you wish take an un fused spur from a 4mm radial in 2.5mm and that it must be taken from the point of supply or a joint box. it looks to me like they are saying you must not take a spur from an existing socket, strange I know, but would value your opinions on that point. (Big Yellow Book)
Still think you will struggle to get 2 x 4mm and 1 x 2.5mm into most sockets, especially the big shed crxp
There are some here that swear getting 3 X 4mm into socket outlets is no problem at all!! I'd hate to think what that connection would be like after pulling and moving those conductors about while getting the socket back into the back box!!
When my colleague is designing he always tends to go for radials unless the loadings or floor area is too great.
Another theory, my colleague has, and I can sort of see the logic is if a 2.5mm2 RFC was wired and protected by a 32 amp MCB, if for some reason the ring broke, and there was a number of sockets on each leg then a 2.5mm2 could become overloaded
No argument about it, radials are easier to install and test.
How old is this Design Engineer, or is he an Engineer?
That's the same old same o, that's been used by those incompetent of installing, testing, and fault finding a ring circuit correctly..... Ring circuits don't just don't suddenly fall apart, without someone's helping hand.... lol!!
Thats a good point, as when I was discussing this with another colleague, he said that you expect only competent persons to be installing the circuit.
The colleague who made the initial claim is someone who thinks anyone working on the tools incompetent. It winds me up daily.
Quite common for those that haven't got a scooby doo what to do with tools!! They tend to become a ''Tool'' themselves!! lol!!
Reply to 2.5mm2 Ring Final Circuit vs 4.0mm2 Radial in the UK Electrical Forum area at ElectriciansForums.net
