I worked for a guy who owned Nightclubs and had a tax haven Villa
in Majorca years ago (20+ years!),
Had to do some electrics and if I remember correctly
first time I had seen an RCD and radials everywhere. (although well dodgy wiring otherwise! it would rain you could see open chock blocks connecting outside lights and sockets sparking in rain !)
I found out then that's how Europeans wired them , and (I think ) they have never used ring main circuits.
We apparently used them because of copper shortage after WW2, However, now I don't see why we use them , what with harmonisation with EEC etc.
When I first done my 2391 and had no clue what so ever about testing , it was abundantly clear when observing, that the most confusing aspect of testing for the guys that had tested was the ring main!
If there was any confusion it was always over that, and associated (R1+R2)/4 equation!
I have wired kitchens where its easier when the circuit has come horizontal along the length of wall to use 4mm Radial rather than have to loop a return in 2.5 mm as such.
Also, a common bodge I come across in houses, is where someone has fitted an additional socket , and simply cut the ring it half and has no clue its reduced the capacity to 20amp, and obviously never changed the breaker from original 32 AMP.(if it works it must be okay philosophy)
IMHO I think, that although you can legally spur off a ring main with a single 2.5 cable which would normally be rated at 20amp, the fact you could plug in x 2 13amp loads to equal potentially 26 amp (forgetting about diversity etc) surely cannot be right?, how does the 32amp breaker know you have done that?
I sometimes find it a bit of a mare' to stick 4mm in the sockets especially spurs , because they are probably designed for x2 2.5mm and not X2 4mm ? not sure, as I think in Europe its a single 2.5 with 20 amp MCB so only ever x2 2.5 mm wires going into it.
The only advantage I can think of is if you have 2 separate earth connections in back of socket and use them, at least if one leg of earth drops/falls out you still have another, and it confuses Europeans LOL.
